卡尔曼滤波中关键参数的调整 来自知乎上官致远
卡尔曼滤波中关键参数的调整上官致远
机器人、运动控制、电机驱动技术
写在前面
对于卡尔曼滤波,大多数人仅限于会用,很少有人能透彻的理解,而关于卡尔曼滤波中那几个关键参数的调整更是一头雾水。自从写完「深度解析卡尔曼滤波在IMU中的使用」一文,很多朋友咨询卡尔曼滤波的参数到底怎么调整,工作之余总结一下,由于水平有限,错误之处在所难免,欢迎交流指正。本篇还是以飞控与移动机器人中常用的IMU芯片MPU6050为例,详细讲解卡尔曼滤波中那几个关键参数的调整。源码参考 TKJElectronics/KalmanFilter
Kalman::Kalman() { /* We will set the variables like so, these can also be tuned by the user */ Q_angle = 0.001f; Q_bias = 0.003f; R_measure = 0.03f; angle = 0.0f; // Reset the angle bias = 0.0f; // Reset bias P = 0.0f; // Since we assume that the bias is 0 and we know the starting angle (use setAngle), the error covariance matrix is set like so - see: http://en.wikipedia.org/wiki/Kalman_filter#Example_application.2C_technical P = 0.0f; P = 0.0f; P = 0.0f;};// The angle should be in degrees and the rate should be in degrees per second and the delta time in secondsfloat Kalman::getAngle(float newAngle, float newRate, float dt) { // KasBot V2-Kalman filter module - http://www.x-firm.com/?page_id=145 // Modified by Kristian Lauszus // See my blog post for more information: http://blog.tkjelectronics.dk/2012/09/a-practical-approach-to-kalman-filter-and-how-to-implement-it // Discrete Kalman filter time update equations - Time Update ("Predict") // Update xhat - Project the state ahead /* Step 1 */ rate = newRate - bias; angle += dt * rate; // Update estimation error covariance - Project the error covariance ahead /* Step 2 */ P += dt * (dt*P - P - P + Q_angle); P -= dt * P; P -= dt * P; P += Q_bias * dt; // Discrete Kalman filter measurement update equations - Measurement Update ("Correct") // Calculate Kalman gain - Compute the Kalman gain /* Step 4 */ float S = P + R_measure; // Estimate error /* Step 5 */ float K; // Kalman gain - This is a 2x1 vector K = P / S; K = P / S; // Calculate angle and bias - Update estimate with measurement zk (newAngle) /* Step 3 */ float y = newAngle - angle; // Angle difference /* Step 6 */ angle += K * y; bias += K * y; // Calculate estimation error covariance - Update the error covariance /* Step 7 */ float P00_temp = P; float P01_temp = P; P -= K * P00_temp; P -= K * P01_temp; P -= K * P00_temp; P -= K * P01_temp; return angle;};void Kalman::setAngle(float angle) { this->angle = angle; }; // Used to set angle, this should be set as the starting anglefloat Kalman::getRate() { return this->rate; }; // Return the unbiased rate/* These are used to tune the Kalman filter */void Kalman::setQangle(float Q_angle) { this->Q_angle = Q_angle; };void Kalman::setQbias(float Q_bias) { this->Q_bias = Q_bias; };void Kalman::setRmeasure(float R_measure) { this->R_measure = R_measure; };float Kalman::getQangle() { return this->Q_angle; };float Kalman::getQbias() { return this->Q_bias; };float Kalman::getRmeasure() { return this->R_measure; };
关键参数使用卡尔曼滤波时需要读取系统起始角度,就是通过读取加速度计的值,然后根据反正切计算出的系统倾角。卡尔曼滤波中的几个关键参数包括dt、Q_angle、Q_bias、R_measure、P。
前缀Q表示预测(过程)噪声方差;
前缀R表示测量(观测)噪声方差;
dt表示采样时间,它的值要特别精确;
Q_angle表示加速度计过程噪声协方差;
Q_bias表示陀螺仪过程噪声协方差;
R_measure表示测量噪声协方差;
P表示误差协方差矩阵;下面简单的看一下当改变参数时系统的输出变化。直接通过读取加速度计的值计算出的角度,我们称为accRaw图中红线表示;通过陀螺仪积分计算的角度,我们称为gyroDt图中白线表示,黄线和白线贴的比较紧,需要放大才能看出;卡尔曼滤波计算的角度,我们称为kalman图中黄线表示;当dt过小时,黄线虽然能跟随红线,但是非常滞后:
dt=0.001
当dt过大时,黄线能跟随红线但明显过冲:
dt=0.010
dt=0.005时黄线可以很好的跟随红线:
当Q_angle越大时,黄线跟随红线趋势越紧密,滤波之后的噪声也越大,下图的噪声明显增大Q_angle=1.0
缩小看一下
Q_angle=0.01黄线跟随红线趋势变缓,滤波效果改善明显
Q_bias越小白线跟随黄线越紧密
Q_bias=0.3
Q_bias=0.003
R_measure值的改变主要是影响卡尔曼的收敛速度,由于测试设备简陋,测试时并没有得到较好的波形输出效果的比较。参数解析Q值为过程噪声,越小系统越容易收敛,我们对模型预测的值信任度越高;但是太小则容易发散,如果Q为零,那么我们只相信预测值;Q值越大我们对于预测的信任度就越低,而对测量值的信任度就变高;如果Q值无穷大,那么我们只信任测量值;R值为测量噪声,太小太大都不一定合适。R太大,卡尔曼滤波响应会变慢,因为它对新测量的值的信任度降低;越小系统收敛越快,但过小则容易出现震荡;测试时可以保持陀螺仪不动,记录一段时间内陀螺仪的输出数据,这个数据近似正态分布,按3σ原则,取正态分布的(3σ)^2作为R的初始化值。测试时可以先将Q从小往大调整,将R从大往小调整;先固定一个值去调整另外一个值,看收敛速度与波形输出。系统中还有一个关键值P,它是误差协方差初始值,表示我们对当前预测状态的信任度,它越小说明我们越相信当前预测状态;它的值决定了初始收敛速度,一般开始设一个较小的值以便于获取较快的收敛速度。随着卡尔曼滤波的迭代,P的值会不断的改变,当系统进入稳态之后P值会收敛成一个最小的估计方差矩阵,这个时候的卡尔曼增益也是最优的,所以这个值只是影响初始收敛速度。结语在实际工程中大家可能都用过PID,算法很简单,但是要想调好PID,实现一定的精度和速度却不是那么容易。这个时候就需要你对系统有很深的理解。卡尔曼滤波的核心代码也就那么几行,但参数的整定却不是那么容易。从反馈角度看,卡尔曼滤波也是一个线性时变反馈系统,逐渐收敛于一个线性时不变系统。最大似然估计方面、反馈系统方面、残差方面以及动态特性方面等都是分析卡尔曼滤波参数的关键之处。在很多工业控制领域,比如飞船的控制、卫星的控制等都有专门的负责调参的工程师甚至是一个团队,可见卡尔曼滤波参数整定的重要程度。从某种意义上说,调参更像是一门艺术。针对于同一套工程模型,这些参数理论上应该可以统一,但是不同环境下系统的过程噪声以及测量噪声有可能不同,因此还是需要实际测试,以便于找到参数的最优值。
参考:xiahouzuoxin/kalman_filter
Kalman filter
